Using the CLFN, a DLL stays in memory until?
According to question 28 on the LabVIEW Recertification Exam (discussed here)
A dll called through the Call Library Function Node (CLFN) in a subVI remains in memory until
c. An empty path is wired into the same CLFN
I've been away from LabVIEW lately - as of 8.5.1 there was no place to wire an "empty path".
Has something changed since?
Is answer "D" correct?
Thanks/Cheers!
"Inside every large program is a small program struggling to get out." (attributed to Tony Hoare)
(3,000 Views)
The ability to dynamically specify the DLL file to use has been added to LV in one of the recent versions. I believe it actually should be in 8.5, but I'm not sure.
I never used it, but I believe you need to explicitly enable it in the configuration dialog (i.e. the default mode is to use a static path).
I don't know what answer D is, but it would seem reasonable that the DLL would be unloaded if you select another (or no) DLL.
___________________
Try to take over the world!
(2,985 Views)
Right you are, tst.
"Specifiy path on diagram"
Thanks/Cheers!
(2,983 Views)
