Using the Clip Plane
Hello, I seek the wisdom of the Labview Gurus.  I have a VI that I can succesfully create objects and display my data.  I can then manipulate the position and do a host of other things that I need done.  Unfortunately, I cannot seem to figure out the Clip Plane.  I have tried using the Create Clip plane VI and then using the property node to add the Clip Plane, but this does not work.  I also created an object called "Clip Plane", added the Clip Plane to that object, and then added Object "Clip Plane" to the parent object.  This did not work either.  None of the examples seem to have Clip Plane usage in them.  Any help would be greatly appriciated.
Austin
PS - The solar system VI was an awesome example in 3d modeling!
(3,367 Views)
I found out my own problem.  To turn on the clip plane, there is a control node under objects called "Set Clip Plane".  Under this is an option to turn on clip planes for the objects.
(3,354 Views)
