Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Using the OK button to set different configurations
Mont
Member
05-01-2002
12:10 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I want to use the OK button to allow the user to select the correct configuration. For example, if the user wants to use configuration 1, then the user can push the OK button to set configuration 1.
0
Kudos
Message
1
of 2
(2,666 Views)
Reply
Re: Using the OK button to set different configurations
Nadav_Chernin
Active Participant
05-01-2002
12:47 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
if i understand you correctrly, you have number of configurations, and one of them user can select.
So, see attached example.
select_config.zip 10 KB
1
Kudo
Message
2
of 2
(2,666 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
