Using the Shared Variable on the network
Dear Sir/Madam
I'm using network published shared variable on the LAN network on diffrent Coputers which have the active firewalls,
When I turn the Firewalls of the computers OFF, I can access to shared variables but when the Firewall is ON I have no access to the Shared variables,
As the company policy I can not turn the computers firewalls OFF,
So would you please help me what setting should I perform on the systems Firewalls so I can access the shared variables.
(2,736 Views)
HI,
Follow this link
fire wall configuration you ask to your network engineer to open some ports for your applications.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(2,730 Views)
