Using the interactive alignment block within a VI
We are developing a simple application to analyse shockwave measurements. We need to compare signals and we found the interactive align block very useful because it does what we want. Is there a way to open the front panel by issuing a command from our main VI?
Piero and Ryan
(2,717 Views)
If you read the manual at page 6-4 it tells you how to create LabView vi's from Signal Express projects. Of course you need the full development system to do this.
https://www.ni.com/docs/en-US/bundle/373873h/resource/373873h.pdf
Hope this helps
Now Using LabVIEW 2019SP1 and TestStand 2019
(2,688 Views)
