Using the polar plot control how do you change the text color. The color of the grid you can change but not the text color.
I am using Labview 7 and the grid color and the text color are not controlled the same for polar plots. Is there a way to control text color for polar plots?
(2,995 Views)
The subVI called PG scale.vi sets the color to a constant of black. To
find it, open the hierarchy window and type ahead PG. You can modify
this subVI to pass in a different constant color, a global value, or you
can change subVIs above it to pass the color info through.
Greg McKaskle
(2,995 Views)
If you do choose to modify the VIs, be sure to save them with a different name in a different directory. If you modify VIs from vi.lib they will be overwritten with the NI standard VI if you ever upgrade. By renaming the VIs you can perserve your code for the future.
(2,995 Views)
