What type of noise are you seeing? random, some sort of offset etc. ?
What is the chassis and its revision that you are using? What is the revision of the SCXI-1520?
The above information will help me in figuring out if indeed there is any issue.
You may also look for the possible causes of the noise by going to www.ni.com/support and type the keywords +scxi +1520 +noise.
Sincerely,
Sastry V
National Instruments.
