Hi Joe,
1. BTW, thanks for the posting directions.
2. The VI to be posted is Traditional DAQ_Reset_Plus DAQmx.vi. It is from the traditional DAQ example directory with added code for Device Reset that produces the lockup problem.
3. The VI locks up after acquisition inside the device reset. Notice the number of channels is important to produce the problem. Lockup occurs when acquiring data with multiple channels. Lockup does not occur when acquiring data with a single channel.
4. The goal is to reset daq card after performing data acquisition with the traditional daq and prior to proceeding with another data acquisition using daqmx.
5. Hardware description: Dell Pentium Mobile 1.2Mhz, Usoft Win2000 & SP4, DaqCard-6062E.
6. The error code (10041) is no longer relevant to this problem. The error was due to using DI/O Clear.vi after DI/O R/W in the application that I’m using. This is no longer a problem. If you are still interested why: per NI “You will get error -10041 if you call DIO Clear without calling DIO Buffer Config. DIO Buffer Config is called by DIO Config, which should only be included for buffered digital operations. Immediate DIO VI's, such as Write/Read to Digital Line or Write/Read to Digital Port, do not require DIO Buffer Config. Therefore, calling DIO Clear without first calling DIO Config results in error -10041. To prevent this error from occuring, do not include DIO Clear with immediate DIO VIs.”
Thanks.
Steve
