Using two DAQ-Plug-in-Boards
I am using two DAQ-Plug-in-Boards in my PC. One is a mulifunctional I/O
card and the other an analog output card. Additionally I need having
some signal conditioning for the digital I/O. To do so, I am using SCXI.
As I want to connect all signal lines at one point, I would like to
connect them all at the SCXI chassis.
Is it possible to connect both DAQ-Cards to one chassis and using two
feed-through modul?
In this way I could access all avaliable lines at one point. Some in
parallel mode, some in multiplexed mode.
Who knows if this works?
Regards
Paul Steiner
HSR Hochschule Rapperswil
Paul Steiner E6d
Oberseestrasse 10
CH-8640 Rapperswil
Switzerland
Fax: +41 55 222 4
400
EMAIL: p2steine@hsr.ch
Message 1 of 1
(7,295 Views)
