Using usb bluetooth instead of internal one
Hi everybody!
i have an interesting question.
I have 2 bluetooth dongle in my computer.one internal and one external usb bluetooth.
My question is i dont know how to use external bluetooth.labview use internal bluetooth as a default and doesn't even try to connect external bluetooth when internal one closed.
it says  "LabVIEW:  The network is down, unreachable, or has been reset."
is there any solution for this situation?
Thanks..
(2,963 Views)
Hello baristogrul,
I would recommend checking out the Advanced Bluetooth Client.vi in the National Instruments Example Finder. This vi scans for multiple devices, and gets the appropriate address and device.
Cheers!
TJ G
(2,945 Views)
Great !
i will check it as soon as possible.
(2,942 Views)
Well i solved my problem:)
i uninstall every program with related to bluetooth.after i uninstall every bluetooth device from device manegar.afther that i pluged in my usb bluetooth device.
after installation finally labview could use it.
the key point is there must be no bluetooth software beside windows's itself.
(2,937 Views)
