Using vision package
This is my first vi using vision package. I was expecting the attached vi to stream the video input from the laptop's camera. When I run it nothing shows up. Don't know what is wrong.
Girish
(1,457 Views)
Delete the input ("Session In") currently wired to IMAQdx Open Camera,  Right-click this input and "Create Constant".  Right-click the little triangle in that constant and choose an attached USB Camera (on my laptop, cam0, the laptop's camera, shows up).  Run the VI -- it will work.
LabVIEW Vision is complicated.  I had several years of LabVIEW and LabVIEW Real-Time under my belt before a colleague "introduced me" to LabVIEW Vision (he needed some help and advise).  I hope you are at least experienced in "non-Vision LabVIEW" before byting off more than you can chew.
Bob Schor
(1,426 Views)
