Using watchdogs in labview and windows
Hi folks,
firstly I come from a microtroller programming background and this is my first project using labview, its been going a while and I've finnished an initial version ready for field tests. The unit is a PXI based system designed to run in remote areas, I've already set windows to automatically start the program however I'm concerned that if a fault occurs that stops labview or windows and stalls, I want to have a watchdog to restart not only labview but the computer. so that it can start fresh. i haven't been able to find any conversations about physically resetting the computer if the labview fails.
thanks for the help
90% of all experts aggree that 1 out of 10 experts are wrong
(3,677 Views)
If you already have set windows to restart your program what is problem ?
You could use error entrap to restart  labview. There is a restart labview package downloadable from Open G
Possible idea
If you could access windows task manager performance dll reference CPU usage so that if surge over 90%
then reboot labview or PC.
chow
xseadog
(3,665 Views)
As to monitoring the CPU usage, the SimpleTaskMonitor.vi  .NET example that came out with LV7.0 would give you that information, but I question its usefulness. I had CPU up to close to 100% when a utility, written by someone else in C++, kicked in briefly. I understand what you are concerned about, and actually in most "mission critical" situations they resort to a hardware watchdog timer. If you base it on Windows and it goes on a walkabout ..., similarly, unless you have another piece of non-LabVIEW code being "tickled" every so often by LabVIEW how do you know when LabVIEW hangs? There are watchdog timers on some NI PXI boards, which would provide you with a method to do a hard reset in case of a failure. I haven't used these (have used watchdogs in other non-LabVIEW, non-NI instances). A search of the NI site with "watchdog" and "PXI" turns up a lot of hits.
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,657 Views)
