Using waveform chart to collect data
I am a new user to labview, however I have been using it for a while now.
I have a simple problem.
My model runs a drive cycle for 1400 secs.
I want to record data for a sample rate of 1 sec.
However, When I try to run the model and export it to excel it shows data for a sample rate of 0.1 seconds. How can I change that?
Also, what can be the maximum buffer size of the waveform chart?
(2,703 Views)
Hey govindgoal,
The max buffer size is pretty massive so don't worry about that. I would post your code or at least the part which is recording the data for people to help debug. It would seem however that you have some timing issues with your application.
Regards
Andy
_______________________________________
"To 'G' and not to 'C', this is not a question!"
(2,683 Views)
