Using wireless network with Real-Time system
Has anyone tried to run a LabVIEW real time system communicating over a wireless network instead of wired Ethernet? Thanks.
(3,669 Views)
You've got the myRIO... running Linux RT and has built in wireless (802.11 b, g, n).
https://www.ni.com/docs/en-US/bundle/myrio-1900-getting-started/resource/376047d.pdf
Otherwise, I haven't done it personally but I think most others will connect a wireless router to their cRIO primary port and connect to a wireless netwoark that way.
Tim A.
(3,630 Views)
Hi Tim,
Thanks for the reply. I was actually hoping to do this with a PXI system. Is there any supporting hardware for that? Thanks.
(3,606 Views)
I would think that all you need to do is hook it up to a wireless access point and the system - whatever it is - wouldn't even know it was hooked up wirelessly...
Bill
CLD
(Mid-Level minion.)
(3,604 Views)
