V I Analyzer - Feature Request: Ignore hidden files
I use Subversion/SVN for source code control and that uses several hidden folders and files on my drive to maintain SCC status - it'd be nice if V I Analyzer ignored these files.  In fact, maybe it's a bug - it analyzes the files,even when they have the odd SVN extensions.  For example: if you have a VI under source code control:
       c:\testercode\test.vi
then you'll end up with another file that SVN creates:
       c:\testcode\test\.svn\text-base\text.vi.svn-base
Although it doesn't have a valid LabVIEW extension, V I Analyzer loads and analyzes this file.
Copyright © 2004-2026 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
(3,185 Views)
V I Analyzer still loads these files when I manually deselect all the hidden .svn folders in the analysis definition.
(3,184 Views)
Hi Crelf,
There has been an earlier discussion on this.
Some OS's don't care about the extension of a file name, and LabVIEW happens to originate from that side of the table.
Ton
My LabVIEW Ideas
(3,169 Views)
Awesome Ton - thanks for the link!
(3,156 Views)
