V-I Measurements with a Keithley 6487 Instrument on LabView
Hello All,
I need to measure V-I characteristic of the silicon photomultiplier using Keithley 6487  programmable power supply. However I don't have that much experience on Labview programming before. I set up the driver for Keithley 6487 instrument. Could you recommend any useful sources to set the block diagrams for this, or share your experience on that with me?
(2,984 Views)
Look at the below article, where shows how to program your device.
https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Labivew-program-for-KE6487-picoammeter/td-p/...
(2,889 Views)
When I reviewed the article you mentioned, I noticed that the links are out of date. Could you please share if you have any information about measuring I-V characteristic automatically using Labview with Keithley 6487?
(2,882 Views)
I,
I guess that in device drivers there is a simple VI on how to set a voltage, how to get your measurments.
(2,859 Views)
