VB Exception Thrown by LVclient
I am trying to use a .dll interop created in LabVIEW for use in VB.  I am trying to use the .dll on a separate machine from the one on which it was created, but the destination machine has LabVIEW Run-time.  However, it seems that the .dll cannot find LabVIEW Run-time.  I am wondering if there is another way I can build the interop or something I can do within VB to make sure the .dll understands where Run-time is.
Image attached showing the VB details for the exception.
Thanks in advance for any help or advice.
-Billy Maier
Message 1 of 13
(4,416 Views)
Hello Billy,
Does the Interop Assembly work on the machine you developed it on?
What versions of LabVIEW, LabVIEW Run-time, Visual Studio, and .NET are you using?
Can you try to make an installer for the Interop Assembly?  This will make sure that the proper version of the LabVIEW Run-time is installed on your target machine. This can be done using the information at the following link:
http://zone.ni.com/reference/en-XX/help/371361H-01/lvhowto/build_installer/
Thomas C.
FlexRIO Product Support Engineer
Message 2 of 13
(4,370 Views)
Yes, it did work on the original machine.
The original machine had LabVIEW 2010 on it.  The destination machine has Visual Studio 2008, version 9.0.30729.1 SP;   .NET version 3.5 SP1; NI Measurement Studio 8.6.35.465; and LabVIEW Run-time 8.6
Unfortunately the nature of this project requires that we cannot install anything further on the destination machine, so we cannot build an installer.
Billy Maier
Message 3 of 13
(4,347 Views)
At http://forums.ni.com/t5/LabVIEW/Problem-with-FGEN-Driver-in-VB/m-p/2997375, you never mentioned that the runtime did not match the version that the interop was developed with. If you can't install a matching version, then why did you even use LabVIEW?
Message 4 of 13
(4,341 Views)
The project adviser did not think the lack of matching would be an issue.  He actually was surprised that we even needed Run-time on the machine.  Also, we were developing remotely and unable to see which version was on the machine at the time.
Message 5 of 13
(4,336 Views)
The project adviser has obviously never used LabVIEW. A matching runtime has always been required just like you need the appropriate .NET runtime.
Message 6 of 13
(4,331 Views)
He is actually quite skilled with LabVIEW but not very familiar with interfacing it with VB.
Message 7 of 13
(4,326 Views)
If he's that familiar with LabVIEW, then he should have been familiar with the concept of a LabVIEW run-time.
Message 8 of 13
(4,321 Views)
The runtime has only been around since version 5.1 or so. The runtime is required for an exe as well as a dll so he's obviously done neither. A quick post here before this ridiculous locking down of your system would have been appropriate.
Message 9 of 13
(4,314 Views)
The system was locked down far before I was put on the project.  Not sure why you guys are being so hostile, I thought this forum was supposed to be professional and friendly.  Either way, looks like we'll probably just have to come up with a driver in VB.
Message 10 of 13
(4,289 Views)
