VB code to control PCI-DIO-96
I've the PCI-DIO-96 card and would like to control with VB code.
Is this possible?
Please advise.
Message 1 of 9
(4,853 Views)
You should repost this to the Measurement Studio board.
___________________
Try to take over the world!
Message 2 of 9
(4,849 Views)
Hello hork,
Your device is supported by NI-DAQmx and Traditional NI-DAQ.  Either of which can be used with VB6.  I would recommend using NI-DAQmx, the next generation data acquisition driver from National Instruments.  Here is a KB that describes how to use NI-DAQmx with VB6.  Hope this helps!
-Alan A.
Message 3 of 9
(4,833 Views)
Hi Alan,
Thank you very much for your recommendation.
The problem was solved.
Best Regards
Hork
Message 4 of 9
(4,824 Views)
Glad I could help.  Best of luck with your project:)
-Alan A.
Message 5 of 9
(4,811 Views)
Hi, Hork
I had same problem for PCI-NI-DIO-96. I used only VB6 without Measurements Studio.
I know you already solved this problem. So, I visited NI sites but I don't know what file is downloading.
There are so many files.
Please infrom me how can you solve this problem and downloading files.
Message 6 of 9
(4,709 Views)
You need to download the most recent version of NI-DAQmx for Windows from this site:  Multifunction DAQ.
Then check out this KB:  NI-DAQmx Support in Visual Basic 6.0.
-Alan A.
Message 7 of 9
(4,703 Views)
Hi Alan
Thanks for your email.
I can solve it.
Have a nice day!
Message 8 of 9
(4,691 Views)
Hi Willis,
I've solved this problem by made the Dll with LabWindows and then the VB6 is call that dll.
Regards
Hork
Message 9 of 9
(4,687 Views)
