VBAI crashes during inspection of large .avi file
I am having trouble inspecting a file. I implemented different steps including finding an edge in a region of interest and measuring the distance to a defined point. In the beginning the procedure works, but after a while the program crashes. I used VBAI to inspect a large .avi file (high image rate. highspeed camera used to make .avi video).
I tried cutting the video with a video-editing software, but after editing the video VBAI wouldn't accept the .avi file.
Any suggestions?
Thank you!
(3,229 Views)
(3,186 Views)
Which version of VBAI are you using?
Which codec are you using?
(3,177 Views)
VBAI 2015 f3 (64 bit)
(3,098 Views)
I am using an earlier version (2015). The program always crahses after inspecting 1155 frames. I am using the simulare acquisition step to analyse an .avi file (approx. 5 GB)
(3,095 Views)
Could you upload on our ftp server the .avi file as well as the inspection? Here is our ftp link: ftp://ftp.ni.com/incoming
Let me know when I can retrieve the files.
T. Le
Vision Product Support Engineer
(3,080 Views)
Earlier versions of VDM only supported 2GB AVI files. What if you upgrade to newest VDM and try reading the file?
(3,075 Views)
