VHDL code, CLIP node XML generator.
i already use this node, but i have some troubles, i used labview fpga,
work good but in some applications with some level of complexity
consumes a lot of resources and also i'm more famliar with vhdl code,
for that reason I have many codes, i would like to use, and this node
look a huge option for me, but i tried using this for a code for ps2
keyboard, i'm declare all, when i declare the frequecy of keyboard
clock seems all good, when i going to the project and added the ip
component element, appears a sign of warning in the icon of ip
componet, when i check it, show me all the in and outputs but the clock
no appears, can something tell me what is going on? please
P.S. sorry for repost this, i hope so, this time do it right.
(3,350 Views)
The clip input clocks are bound to an actual clock on the 'Clock Selections' property page of the clip instance. If the clock isn't showing up on that property page then there might be something wrong with the clip declaration xml file. If you're still having trouble, could you post the relevant pieces of your project so we can see what's going on?
(3,329 Views)
