VHDL code with Serial Input
I would like to use an NI 9870 Serial Module as an input source for a Component Level IP block. I would like to use the read byte method for the NI 9870 at a baud rate of 9600. Should I use a counter in VHDL to cut the 40MHz on board clock down to 1200Hz or is there a better way to determine when a byte would be ready?
(3,605 Views)
Hello imr,
If I understand your problem correctly, you seem to be looking for a read solution with the 9870 that transmitts data to a CLIP of yours at a specified rate. A counter would be a good way to achieve a loop rate that would would allow you to synchronously pass data to the clip relative to your baudrate.
Best,
Blayne
(3,558 Views)
Hi Blayne,
Well the rate doesn't need to be specified, it is a function of the serial transmission speed. A design that took any speed input from the serial read function would be preferred. The example is good, except that I don't see how repeated characters make it into the FIFO when the only input is the integer from the read function and nothing else. I think I am going to try a solution with a target based FIFO that collects the data, and a CLIP that looks at the buffer size and reads if it is greater than 0.
(3,547 Views)
