VI Analyzer - Find sub-VI calls by path name
Is it possible to use VI Analyzer to detect and report if a specific sub-VI (identified by path name) is used within an analyzed VI?
I am upgrading from LabVIEW 7.0 to 8.6. I need to identify the use of specific VIs and replace them with new LabVIEW native functions.
I could delete these sub-VIs and look for broken VIs, but they happen to be part of LabVIEW's 'vi.lib\' hierarchy, and I would rather not edit or delete them. Smiley Wink
Message Edited by Phillip Brooks on 10-30-2008 01:56 PM
(5,491 Views)
Accepted by topic author PhillipBrooks
Hi Philip,
I've attached a VI Analyzer test below that should do what you want.  In addition to looking for static subVI calls, it also checks string controls/constants and path controls/constants for the VI name you specify, in the event that you have dynamic calls.  To use this test in LabVIEW 8.6 do the following:
  1. Copy the attached LLB to [My Documents]\LabVIEW Data\VI Analyzer Tests (you may need to create this folder).
  2. Run Tools > VI Analyzer.
  3. Specify the folder(s) of VIs you want to analyze.
  4. On the test selection page, place a checkbox next to <User-Specified>\VI Analyzer Tests\Find VI Calls.
  5. Type the name(s) of the VI(s) you want to search for in the "Offending VIs" list on the right.  I recommend excluding the ".vi" extension...I noticed once when I was looking for a VI that the subVI name wasn't what I was expecting.  In my case, the name I specified was "Write to Spreadsheet File.vi", and the VI on the diagram was "Write to Spreadsheet File (dbl).vi" because it was a polymorphic VI.  Since this test matches case-insensitive partial strings, I just specified a name of "write to spreadsheet file" and it was found.
  6. Run the analysis.
Let me know if you have any questions or problems.
-D
(5,469 Views)
If I could give you 10 kudos right now, I would! This is PERFECT!
Thank you so much!
(5,464 Views)
