VI Analyzer - how to change default bounds for screen res?
Hi!
Very simple question. VI Analyzer reported "This VI's front panel does not reside entirely within the specified bounds (1024 x 768)." For us it should be 1280x1024. How we can change these "specified bounds" to other resolution?
Thank you,
Andrey.
(2,979 Views)
In the "Select Tests" page of the Analyzer UI, select Front Panel>>User Interface>>Panel Size and Position. By default, the configuration page uses a user specified resolution. To change this, modify the "Maximum Panel Width" and "Maximum Panel Height" control to your desired resolution.
George M
(2,973 Views)
Thank you very much! That was so easy... I haven't seen options on the right side. Probably weather is too hot here in Germany...
(2,964 Views)
