VI Can't Open
Hello Everyone,
I have developed a LV project which one including ms-sql db connection functions last year. But I can not open project or any vi file now.
I tried some actions like rename vi, drag vi to empty block diagram, create a empty project and add vi, etc. but I did not success.
The project has been developed LV2012 and I am using same version LV now.
I attached some VI files from my project.
I hope anyone can help to me.
Fatih.
(4,904 Views)
Hi YFA,
I can open both VIs. They are still saved with LV2012…
(4,902 Views)
Those VIs are fine. Can open them without any problem...
What happens when you try to open them? A message, an error, a crash?
(4,874 Views)
ave you done recent changes to the computer software?
(4,847 Views)
Both VI can be opened,You'd better show the open failed message or get a failed picture.
(4,829 Views)
hello ,you can check the software that has been installed successfully,if ok,you can try on the vertion of 2013 or more higher.
(4,806 Views)
Hello All,
I moved the project files to different path after your feedbacks and my project is working now.
I am not sure but thinking the source of problem was different language of backuped computer and new computer. Backuped Project path was including Turkish characters.
Thanks for your help.
Fatih.
(4,783 Views)
