VI Conversion from 7.1 to 6.1
Would like to convert vi's from version 7.1 to 6.1, but i don't have version 7.0. Is there someking of tool available to do that? I would have to do it every month or so, so i need a tool that i can work with on my own.
(2,915 Views)
If you need to convert back to 6.1 (presumably for sharing with a colleague or client), then you cannot use any 7.0 or 7.1 features in your code.
Why not then work in 6.1? Is there some environment feature that's handy in your 7.1 ? Or do you not have 6.1 either?
Steve Bird
Culverson.com
LinkedIn
(2,915 Views)
The need comes from the fact that we(LabVIEW coders in my company) are working in 7.1 and that there is others(engineers, scientist,,,) that are still in 6.1. So we would like to be able to share our libraries with them, by converting them to 6.1 every month or so.
(2,915 Views)
Then use that as leverage to get the laggards up to 7.1.
If that won't happen, then use 6.1 yourself. I did that myself when I had one client with 6.1 and another with 7.0. I just kept two versions handy.
Failing that, I don't know of a tool that goes directly from 7.1--> 6.1. If you have even one copy of 7.0, you could use that.
Steve Bird
Culverson.com
LinkedIn
(2,915 Views)
