VI Documentation - Printing Front Panels in a Broken VI Tree
Hello there,
I'd like to print all the front panels in a VI tree I've created, similar to the Agilent 34401 example here:
C:\Program Files\National Instruments\LabVIEW 8.2\instr.lib\Agilent 34401\Public\VI Tree.vi
Is this possible to dump the all the Front Panel images using the standard LabVIEW Print dialog?
-Chroma
(2,517 Views)
Hi Chroma,
You can print all the VIs in the VI hierarchy.
1.  Select File » Print... » Multiple VIs
2.  Select Add VI Hierarchy...
3.  Select the VI that contains VIs you want to print (in the Agilent Example it would be VI Tree.vi)
4.  Click Next
5.  Select Complete front panel
6.  The rest should be self explanatory
Stanley Hu
Applications Engineering
http://www.ni.com/support
(2,488 Views)
