VI Front Panel to PDF
Hi all,
        Need some help to store VI front Panel to PDF. Im using 'Dopdf' application to convert the front panel to pdf.
My requirement is i need to save the PDF file name programatically instead of popping out a window to browse pdf file path and file name.can any one please suggest any API or dll??
Thanks in advance
Jayavanth.G
(6,379 Views)
Is this helpful?
http://zone.ni.com/reference/en-XX/help/371361G-01/lvreport/easy_print_panel_doc/
You could use that to make your own app in LabVIEW.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(6,355 Views)
hi,
    can u please throw some light on the sentence "You could use that to make your own app in LabVIEW." The Funtional pallete link which you have provided takes the VI file path and the printer name, but i need to enter the file path and file name of the PDF.
Thanks in advance,
Jayavanth.G
(6,346 Views)
An easy way is to use the ITextSharp toolkit, you can download it from the following link: https://decibel.ni.com/content/docs/DOC-10952.
Here is an application example an the resulting pdf.
Ben64
(6,333 Views)
I was thinking more of using something like this: https://decibel.ni.com/content/docs/DOC-25831
Attached is a simple version.
jigg
CTA, CLA
testeract.com
(6,305 Views)
