VI Logger and counter digital output
I would like to know if it's possible, when using VI Logger (full) to use a counter output using a PXI-6229 card.
We want to used the counter output when the value is withing the range and stop counting when the value is outside the range. I know how to toggle a digital output, but I can't seem to find a way to use a counter output.
Thanks !
(2,305 Views)
Crusader,
Thanks for contacting National Instruments.  This is a common question, but VI Logger does not log Counter data or digital data.  It is made for recording analog data.  You can start acquisition with a digital signal, but that's the extent of digital support .  Counter/Timers are not supported in VI Logger.  It also does not support any output of any kind.
Kenn North
Principal Product Manager - Search, Digital Analytics
http://ni.com/search
(2,293 Views)
