VI Logger lite refuses to display data in real time.
Rather, all data are splashed onto the display at the termination of logging. How can this be converted to a real time display?
(2,348 Views)
Hi 45249,
If, when you created the DAQmx Task that is used in your VI Logger Task, you selected "N Samples" for the Acquisition Mode, then all N samples will be acquired by the DAQmx Task before returning the data to the VI Logger Task for logging and display. If you Select "Continuous" for the Acquisition Mode, then the DAQmx Task will return each sample to the VI Logger Task one at a time. This will show you a real-time display in the Real time Data window. I hope this information helps.
Have a great day,
(2,332 Views)
