VI Scripting Event Structure - User Events
Hi There,
I am trying to write a VI script that will look at an event structure in another VI and populate the event structure with the registered user events wired into the dynamic terminal.
I am using the "SetHandledEvents" invoke node and wiring up the Dynamic Events terminal.
In my example VI I have created 3 user event num, bool and string. I can right click and add the event just fine to the event structure. Now if I delete all the event cases, and Run my script I can add one of the dynamic user events. If I change the event gegistration number from 1 to 2. I get error 1. The event case is created but it is not configured for any event.
Any help would be greatly appreciated.
Images of my test vi showing the three user events I am registering.
Attached is the VI containing my script.
Thanks in advance
Kev
(5,793 Views)
CAR 544533 was filed somewhat recently about this issue. I really thought that the DQMH did this automatically but I may have been wrong. I know they script a lot of user events so you might be able to look through what they do if the tools are open.
https://www.ni.com/en/support/downloads/tools-network/download.dqmh-.html
(5,750 Views)
Accepted by topic author K.Ross
The error 1 user event scripting issue should be fixed in LabVIEW 2016. DQMH does do a lot of scripting of events, but it is unable to automatically configure event frame names...the user has to do that manually for now.
(5,730 Views)
Hey
Thanks for the reply. Sad news. I will wait for LV 2016 hopefully will be out soon.
Kev
(5,707 Views)
Recent history shows that the new LabVIEW versions are release around the time of NI Week.  That is the first week of August.
(5,668 Views)
CAR 544533 has been fixed in LabVIEW 2016. Please see the LabVIEW 2016 Bug Fix List for more information.
(5,505 Views)
(5,298 Views)
