VI Scripting - locate loop iteration and conditional terminals.
I have inherited some very poorly written LabVIEW code, which consists of VIs with huge block diagrams and multiple humongous loops… think scrolling through multiple screen heights and widths! It is painstaking to find each loop's iteration terminal and conditional terminal (stop terminal). Is there’s a way to do this with scripting?
Message 1 of 12
(4,652 Views)
See if the following code will help you.
You can search for WhileLoop and for ForLoop and get references to the LoopCounter and the LoopEndRef of the structures.
You should build a tool which lists the terminals and gives you the possibility to highlight one LoopCounter or LoopEndRef at a time.
Message 2 of 12
(4,614 Views)
Accepted by topic author TeraTech
Hi TeraTech,
Yes it is possible by using a right-click plugin. You can create one by running VI "<LabVIEW 20xx>\resource\plugins\PopupMenus\Create Shortcut Menu Plug-In From Template.vi". It will create a new plugin and place it in "<YourUser>\Documents\LabVIEW Data\PopupMenus\edit time panel and diagram" so that all your installed LV versions (superior or equal to the one used to run the VI) can see it.
Attached is an example for your use case, put the .llb folder in "<YourUser>\Documents\LabVIEW Data\PopupMenus\edit time panel and diagram". Then restart LabVIEW and try to right-click a loop, then you can see the new Find->Iteration Terminal / Conditional Terminal options. Works for LV versions >= 2021.
Raphaël.
Message 3 of 12
(4,600 Views)
You read my mind!  I eventually wanted to create a right-click plug in for it. Thanks for the code.  Unfortunately, I can't try it out right now, we're still on LV2017.  😞
Message 4 of 12
(4,593 Views)
@raphschru wrote:
Hi TeraTech,
Raphaël.
I installed LV 2021. Downloaded and unzipped "Find Loop Terminals.zip". Copied the resulting folder "Find Loop Terminals.llb" to the folder "C:\Users\<USER>\LabVIEW Data\PopupMenus\edit time panel and diagram"
I started LV2021, created a new VI with both a for loop and a while loop.  When I right click, either the For or While loops, I don't see a Find menu as you described.
Message 5 of 12
(4,565 Views)
I ran "Create Shortcut Menu Plug-In From Template.vi" and gave it "Find Loop Terminals" as a name. The resulting VIs were placed in the "...\Documents\LabVIEW Data\PopupMenus\edit time panel and diagram folder", but they just templates. So I pasted the code you provided into the VIs with the same names and update the ctl file of the same name.  Saved all.  Exited LV. Restarted LV and tried the right click on a while loop. Still missing the "Find Iteration Terminal" or "Find Conditional Terminal" selection. I've attached the llb file. What am I missing?
Message 6 of 12
(4,536 Views)
Works OK for me.
Message 7 of 12
(4,534 Views)
Raphaël.
Thank you Raphaël for uploading the Plug-In, it is really helpful
Works for me in LV2022Q3
Message 8 of 12
(4,473 Views)
It reminds me of this thread, @paul, did you eventually find what caused the issue ?
https://forums.ni.com/t5/LabVIEW/Missing-Popup-Menus/m-p/4267046
Message 9 of 12
(4,459 Views)
I did solve it, but I don't remember what the solution was.
At this point, my best guess would be that there was a buggy version of the popup located at ...\labview 2019\resource\plugins\PopupMenus\edit time panel and diagram\
Message 10 of 12
(4,446 Views)
