VI Scripting problem
The function "New VI Object" inside the "VI Scripting" do not work properly in the EXE application using LabView 2014.
How I can solve this issue?
Thank you for your answer.
Andrea
(3,870 Views)
Hi Andrea,
VI scripting in general does not work well in executables (aka "isn't supported") - so what's your problem?
(3,857 Views)
Accepted by topic author ca1981
The RunTime Engine cannot use scripting nodes because it does not have a compiler.  Scripting will only work in the development environment.
(3,833 Views)
I think that what you said is the motivation. I suspected that was as you said but I asked for confirmation.
Thank you very much for your answer.
Andrea
(3,811 Views)
I used script to generate in automatic the panel with led objects starting from a configuration file.
In the development environment it works. I wished to used this system also in my executable to have a dynamic creation of the panel interface.
But I think that this functionality is not supported for the matters that explained the user below. Thank you very much for your support.
Andrea
(3,808 Views)
