VI Server functions
Hi there,
I`m pretty sure I`ve read something on this before, but I can`t find the
information.
I have written a VI which programatically outputs the documentation to HTML
files, which all works super in the development environment, but which as a
stand-alone EXE does not work at all.
Is this function available outside the LAbVIEW development environment?
Shane
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(2,805 Views)
The Print VI Documentation (HTML, RTF, etc) methods are NOT supported by the run-time engine. You will get an error message out of the invoke node which calls these methods in the run-time environment.
-Jim
(2,805 Views)
