VI WORKS, EXECTALE NO
WELL I AM WIRTTING THIS TO EXPLAIN WHAT HAPPEN TO MY PROGRAMME...WHEN I RN A VI ALL RUN PROPERLY...BUT WHEN I CRATE THE EXECUTBALE STOPS, AND DOEN'T WORK...WHAT HAPPENS????
I ATTACHED THE VI!!
Message 1 of 13
(3,817 Views)
Hi Alan,
your CapsLock key has some problems - or do you cry at us?
Well, from looking at your code I would say there's a broken VI. So it will not run in development mode either...
Message 2 of 13
(3,812 Views)
sorry , i have writte in capital letters and i have not notized!!!
sorry bronken VI?? yes?? well...i don't understant what is the meaning when you say this, in my pc works fine the VIs
Message 3 of 13
(3,808 Views)
Hi alan,
so what does it look like:
Message 4 of 13
(3,802 Views)
sorry, like this,
Message 5 of 13
(3,799 Views)
any idea???
Message 6 of 13
(3,777 Views)
Hi alan,
- firewall settings checked?
- error cluster checked? When the exe "doesn't work" it should output some errors in the critical code section...
Message 7 of 13
(3,772 Views)
firewall is no enabled, and the cluster error is ok....
only appeares error 1043 invoke not find........
Message 8 of 13
(3,769 Views)
Hi alan,
what does #1043 mean? Did you read the explanation?
"This property or method is not supported by this LabVIEW version" (translated from my German LV)...
Message 9 of 13
(3,767 Views)
yes that is the error, but i have no idea of what must i do!
Message 10 of 13
(3,761 Views)
