VI analyzer and dialog-style control.
When using VI analyzer it comes up with an occurance that states "The control labeled "whatever" is not a dialog-style control. Because of this, its appearance will not be platform-specific." What is the significance of this message and the pros and cons of not using controls from the system pallette.
Using LV 8.2 and TS 3.5
Now Using LabVIEW 2019SP1 and TestStand 2019
(2,946 Views)
Use the controls from the System palette when you want your UI to look like standard dialog UIs in your operating system.  For analyzing any other kinds of VIs (test VIs, subVIs, instrument panel VIs, palette VIs, etc.), you should deselect this VI Analyzer test to reduce the amount of "noise" in your results.
-D
(2,940 Views)
