VI displays error of type 4A340 in built executable (LV8.0)
I've had this error for about a month so far. I've tried calling support but they were not able to come up with an answer.
I have a VI which includes NI-Motion, NI-IMAQ (no vision) and NI-DAQ components. This VI builds fine and works as it is supposed to. The problem is that when I build an executable it doesn't show any errors, but when run it displays the message: "VI has an error of type 4A340. The full development version of LabVIEW is required to fix the errors."
I've seen this error in quiet a few posts so far. However I'm not using NI-VISION and my hierarchy is absolutely fine and running on a fresh install of WinXP and LabView 8.0. All of the drivers are off the LV 8  installation CDs. All of my created files reside in the same directory. I'd appreciate any help with this.
Message Edited by romulus on 01-11-2006 11:00 AM
(2,677 Views)
-bump-
(2,637 Views)
Well just an update. I managed to solve the problem by installing the latest version of IMAQ for LV 8.0 which is IMAQ 3.5.1 instead of the original 3.5.0. I hope this helps someone.
(2,627 Views)
