VI documentation feature broken in labview 8.0, 8.20, 8.21, 8.5
Also, the waveform data type does have an error cluster. I can't tell you what it's for, since I never used that data type, but you can see it, for instance, if you wire a waveform into an Add primitive. The same applies for dynamic data.
___________________
Try to take over the world!
Message 11 of 13
(812 Views)
To me that seems like the add function has error in/error out terminals explicitly.  So if I can explicitly wire the error cluster in and out of the add function, why is a duplicate error cluster carried with the waveform.  And if a duplicate is carried with the waveform, why can't I get to it with unbundle waveform?
-Devin
I got 99 problems but 8.6 ain't one.
Message 12 of 13
(807 Views)
As far as I can tell, there is only one error cluster and it belongs to the waveform.
As for why it can't be accessed using the unbundle primitive, I have no idea, since I don't know what it means and how such errors can be generated.
___________________
Message 13 of 13
(797 Views)
