VI fetches always same data from digitizer
I route my started signal from generator via RTSI to digitizer. I use that one to start acquisition. Unfortunately my fetch VI always fetches the same data from digitizer.
Actor Framework
Message 1 of 13
(2,535 Views)
Sorry, I can't look at your VI (No LabVIEW 2021 here), but the following just seems to be quite silly by just looking at the picture:
I am sure there are slightly better ways to create an empty 1D array from an arbitrarily sized 1D array than what you are doing on the left.
How many elements are in the array coming from the read? If there is only one element, the entire shift register construct could be replaced by a concatenating tunnel at the right boundary. If there is more than one element, you are creating a scrambled mess when inserting at [i].
Which part does the "Fetching"?
Message 2 of 13
(2,519 Views)
Since I don't dig into the compiled output I can assume that this operation sets basically the array's size and capacity to 1.
There is only one element. I didn't think of a concetenating tunnel, so thank you for suggesting it, but this doesn't solve my problem.
The NI-Scope fetch VI should do the fetching.  (The one with the 1D Cluster option under it)
It seems to be quite silly to me, that I maybe should reconfigure a digitizer for every time I want to have a triggered acquisition? But this is not clear to me, since the documentation is not clear about that.
Actor Framework
Message 3 of 13
(2,493 Views)
Not, it empties the array (i.e. size=0). Arrays don't have any defined "capacity" (whatever that means). The maximum number of elements is limited by the range of I32.
Message 4 of 13
(2,482 Views)
Sure 0. Size in the manner of elements size and capacity in the manner of number of elements allocated for that array. So actually it will only set capacity to 0, it won't touch element size.
Actor Framework
Message 5 of 13
(2,461 Views)
Accepted by topic author Quiztus2
By switching from exporting started event to start trigger and adding initiate acqusition as in the screenshot the problem is solved
Actor Framework
Message 6 of 13
(2,451 Views)
You probably mean element type. Clusters never have variable size. (Equivalent (but simpler) code would be a resize with length=0, for example. or just use a diagram constant of that empty array. :D)
Glad you solved your primary problem. At this point you probably can delete all that pink garbage on the left that's not even used. As a matter of caution, you typically want to put references in shift registers across FOR loops. If you don't, they have the potential to become invalid if N ever happens to be zero due to some unusual situation.
Message 7 of 13
(2,428 Views)
Actually this advice can be applied to any value that you care to propagate across a FOR loop if it ever encounters an empty array.
Bill
CLD
(Mid-Level minion.)
Message 8 of 13
(2,410 Views)
So the array holds actually only pointers to the clusters?
I clicked through tons of beatiful context menus of nearly everything, but I cant find a way to create a reference from an array in the block diagram to pass it into a for loop.
Actor Framework
Message 9 of 13
(2,384 Views)
What do you even mean by that? If it is an array on the block diagram, it is a diagram constant. Why would you need a reference and why would you need to pass it into a FOR loop???
What does your picture have to do with the question?
Please don't dissect semantics. Maybe start with some easy reading. 😄
Message 10 of 13
(2,367 Views)
