VI has an error of type 1002288.
Developing in Windows XP using LV2010 SP1 and Vision Development Module 2011. Deploying on Windows 7 64bit computer with NI IMAQ 4.5 amd VISA 5.0 as well as the vision runtime environment.
I was getting an error that alluded to a sub vi missing. I checked "save settings for all contained items" under source file settings under build properties.
The target machine has been running a previous build of this software that a colluege made (he quit and left it with me). So I don't think this is a compatability problem. Am I missing a build setting? I have no clue what this error means.
(3,165 Views)
Hi
Have you already see this post ?
http://digital.ni.com/public.nsf/allkb/A0DC939E3405D37E86256F40001E17D4
It seems to be similar as your problem.
R. Kaszubiak
(3,161 Views)
Yes, I saw this. I verified each point. One possible issue was that my project was on a network drive & libraries were local. I preformed a source distribution and put the project locally on my computer. The dependencides automatically mapped in. Everything runs A-OK on the development PC. I still get the same error on the runtime PC. With default build options I get this error instead:
The error LabVIEW resource not found:
An error occured loading VI 'NI_Vision_Development_Module.lvlib:IMAQ Set Calibration Info'
LabVIEW load error code 3: could not load front panel
Am I missing some option to pack all of the dependencies up?
(3,131 Views)
Accepted by skoralesky
The problem seems to come from the runtime because of all is OK on the local computer which has all software installed in local.
There is two possible solutions :
- a runtime problem :
If you use the NI Vision Development Module, you must have the NI VISION Runtime that you must pay.
- a camera promblem :
I you use a National Instruments camera, the runtime is integrated in the drivers and it is free but if it is not a NI camera, sometimes you have to paid Runtime IEE 1394 license.
 R. Kaszubiak
(3,120 Views)
The runtime computer had rev 2010SP1 while the development PC had rev 2011 of the vision runtime software. I updated the runtime PC and that solved the problem. Thanks!
(3,117 Views)
It is a good thing.
I am happy that your problem is solved.
Best regards.
R. Kaszubiak
(3,111 Views)
