VI help required on labview.
Hi Again
   As i have mentioned before that i want to make usb daq card based on 18f4550 . it has 8 analog inputs, 2 analog outputs , 8 digital inputs and 8 digital outputs.
In this regard I have developed the labview code for communicating with the usb daq card mentioned  and the VI is attached also. Please tell me how to  add the 8 analog inputs of ADC on this VI out of which the one i select sends a particular code to the pic18f4550 ,which recognizes that code and enables only that input channel and voltages of that channel appear on VI . Similarly in the attached VI , i want to add two analog PWM outputs such that what ever duty cycle value i write in labview , the corresponding voltage appear on the ccp pins also and 8 digital inputs and outputs each.
please just go through  user.c  and user.h for better understanding what i am trying to say.
I am very close to achieve my target but stuck in the above mentioned problem of HOW TO ADD THESE FEATURES.
PLEASE help me by editing the above VI and add these features and dont forget to include MPUSBapi.dll in the labview folder.
The main VI in labview folder is VI driver3. please help me.
(2,869 Views)
one thing more i have to add
(2,868 Views)
(2,820 Views)
