VI in RUN mode refuses to STOP
I have attached a very peculiar VI. This VI will RUN but refuses to STOP because ALL the sTOP buttons refuse to function. Can it be repaured?
Message 1 of 14
(4,180 Views)
You will have to include subVIs amongst other things in your attachment. Then I have a chance running your VI to see whats going on.
Regards
Anders M
NI Denmark
Message 2 of 14
(4,158 Views)
I have attached the complete VI. It is in LV 6.0. Hope it helps. All the Best
Message 3 of 14
(4,157 Views)
You have removed the backpanels so carnt convert from 6.0 to 7.1, need backpanels to help you.
Regards
Paul
Message 4 of 14
(4,155 Views)
Or someone with 6.1 could take a look . . . Which I don't have at the moment.
Sorry!
Bob
Message 5 of 14
(4,153 Views)
Just tried using 6.1, but you have saved the VIs without Block Diagram, so there is nothing I can do.
Save again with BD!
Regards
Anders M
NIDK
Message 6 of 14
(4,147 Views)
You'll have to save the VIs with the block diagrams. We need to be able to see the code to figure out what's going on.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
Message 7 of 14
(4,144 Views)
I had to delete all of the subVIs in order to run it. After that, I could stop the VI. You said "ALL the sTOP buttons refuse to function". There is only one button that will stop the VI. It's the abort button. Start the program and just press the abort. Does it stop now? If it doesn't, then its possible that one of the subVIs is stuck in a loop. since you posted the subVIs without diagrams, no one can look at them.
Message 8 of 14
(4,138 Views)
Your top loop's initialize is never run. The wire coming from the Create Queue and Insert Queue Element is connect to the output of the create queue instead of the output of the insert queue element. This means that the User Abort Setup indicator is never getting set. Its value ANDed with anything will always be false, never stopping the lower loop.
Hope that this helps,
Bob
Message 9 of 14
(4,133 Views)
I am attaching the complete VI. Earlier I did not use custom save. Thanks.
Message 10 of 14
(4,101 Views)
