VI is paused and while loop highlighted
I am running parallel while loops, and for some reason when it should start to run the loops, it pauses the VI and highlights one of the loops. It was not doing this last week when I ran it so I am not sure what the issue is. I included a screenshot of the beginning of the code, the loop that is highlighted is the one on the bottom right. Also, what is the red dot on the error wire right after the sequence structure??
(2,618 Views)
Accepted by topic author lvuser333
Someone snuck in a breakpoint on you.  😉  The red dot is the breakpoint and that is why your VI pauses.
Bill
CLD
(Mid-Level minion.)
(2,610 Views)
the red dot is a breakpoint - and it's the reason for stopping/pausing your VI and highlighting the while loop...
Right click the breakpoint to delete it. Or open the breakpoint manager...
(2,608 Views)
