VI not displayed after building
After updating the values in the configuration (assuming the write key.vi worked) the vi remains until remains until the user presses exit. Here is the vi.
Message 11 of 13
(595 Views)
Hi NJS,
I am going to run through your VI and turn it into an executable. Can you also post your sub VI "ClearSection2" so I can put that in the project as well.
Ricky
Message 12 of 13
(580 Views)
Accepted by topic author NJS_Prog
Hi Ricky, I was searching the forums when I came across this
Problem with .exe and vi.lib
I tried copying the vi.lib folder and placing alongside the exe and it worked for me also.
Im sure its not the best way but it is a workaround.  The solution posted on that thread did not work for me.
I really appreciate your help guys.
Thanks and have a Merry Christmas,
Noah
Message 13 of 13
(571 Views)
