VI of the Day (9/4/2009)
Knight of NI
Re: VI of the Day (9/4/2009)
Message contains an image
Are you using the right frequency? Try this:
middlec
That should be middle C.
Harold_Timmis
Active Participant
nope I tried it and still no noise
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcomeSmiley Happy
Darin.K
Trusted Enthusiast
Message contains an attachment
Name that tune.  Not enough time to tweak it (and my pitch is terrible), but I think it is recognizable.
Note this works just fine for me on LV8.2.1 with XP or Vista.  Be sure to disable the system beep.
altenbach
Knight of NI
Montreux is a hint Smiley Wink
altenbach
Knight of NI
Now all we need is a reentrant beep.vi so we can do polyphonics. Smiley Very Happy
stevem181
Active Participant
Message contains a hyperlink Message contains an image
The mystery tune is pretty easy for those of us that went to HS in the 70s - nice job.
Below is a simple alarm vi that toggles between the system alert and the synchronous beep modes. I think the combination makes a reasonably good alarm sound. If you control the on/off with a queue, you can set up a very simple application wide alarm.
steve
www.ashfordsolutions.com
Founding (and only) member of AUITA - the Anti UI Thread Association.
NitinD
NI Employee (retired)
Does your computer beep when you boot it up? I had a machine in which the internal speakers were disconnected, so I got no sound in that machine.
Harold_Timmis
Active Participant
I just restarted my computer and no beep..... so I don't know how it was diconnected because it is a laptop and I havn't done anything with it hardware wise or software wise really.....
Harold Timmis
htimmis@fit.edu
Orlando,Fl
NitinD
Well... I've not tried the VI on my laptop. I'm not sure of how laptops are built inside. Usually the desktop CPUs are connected to a small speaker internally, which gives the beep...
Come to think of it, I don't recall my laptop beeping during boot up either, which means that beep.vi shouldn't work on it too, if my hunch is correct. I'll confirm and get back to you.
Harold_Timmis
Active Participant
Sounds good I would like to mess with the beep.vi but never have had the opportunity so I normally use the lvsound.llb
Harold Timmis
htimmis@fit.edu
Orlando,Fl
