VI "FindInstrumentDrivers.vi" was stopped at node "" at a call to "IDF_WsIdOpen.vi"
This what I get trying to download Instrument Drivers in LabVIEW 8.2. LabVIEW 8.6 doesn't succeed either. any ideas?
(2,219 Views)
Could just be an intermittent server problem. Does this happen all the time? At what point does it fail? When you first launch it, after you login? The network traffic indicates that it uses port 3339. Is this being blocked by your firewall?
(2,197 Views)
