VI "instances" in Desktop Execution Trace Toolkit
The last couple days I've been using the DET toolkit in depth for the first time to track down some .Net memory lakes in my code.  In the Configure Displayed Events --> VIs dialog, I found a couple vis that have duplicate entries.
Most vis are listed as:
MyLibrary.lvlib:MyClass.lvclass:MyMethod.vi
Two vis are shown* as:
MyLibrary.lvlib:MyClass.lvclass:MyMethod.vi:Instance:0:1
(*In this case I have to read the tooltip.  The dialog isn't resizable Smiley Mad and there's no scrollbar for me to directly view the interesting part of the name.)
The obvious reason would be if these vis were marked as reentrant.  They're not.  Neither are any of the vis in their call chain.  Anyone know what could cause this?
(2,250 Views)
Hi Daklu
I am trying to look into this, but I need to know more . Would you mind posting a few screw shots and the DET report?
Joe Daily
may the G be with you ....
(2,235 Views)
