VI's bogging down?
@chuggins143 wrote:
Nope, not sure what a "chase condition" is...  ??  I'll have to go look that up.
Look up the phrase "race condition", you'll have better luck finding information on that.  I think aeastet was making up a new phrase that almost sounded the same.  Smiley Wink
Message 21 of 53
(1,349 Views)
Jeff,
The file I'm reading is a TXT file... no macros.  I have LV writing to a text file which it does happily, and then have Excel run a macro that goes and gets the data and then LV deletes the txt file.  This is basically what my buddy calls the "hole in the tree" method of transfering data.  I have two txt files in the background, one is for pulling my target points from Excel and LV is looking at that file with each iteration and updating the targets. The other is for transfering data and is deleted at the end of the cycle so there is no way to have data overlap, it's a fresh file each iteration.   I know there is a way to have LV reach directly into Excel, but using the txt file ended up being much easier and quicker to program.  I'm pretty good with VBA and getting it to do what I want so that part was easy.  ..and LV readily writes to a txt file without me having to jump though a bunch of hoops unlike trying to write directly to Excel.
All,
If you guys have a suggestion where to learn programming styles and such, I'm more than willing to learn.  I just started at point A, got that to work.. added step B, got that to work... and so forth.   I guess I really don't understand the difference between a "express" VI and a... "regualar" VI...  I jumped into LV programming head first and may have missed some of the finer points.  I started with the Measurement Computing graphical interface that was shipped with their hardware a while back (SoftWire for VB.Net) so that gave me some false security when I jumped into LV.
THX
C
Message 22 of 53
(1,343 Views)
@chuggins143 wrote:
I would love for this to all fit on one screen!   But as I developed it, it kind of kept getting bigger....  It started as one loop looking at a voltage reading and opening and closing two relays based upon the target and the parameters I set forth.  That grew to three loops... I then needed a timer that would pulse the out put to the relays.. and then I needed to write to a file.  I'm still in the "development" phase of this project so I don't want to start throwing everything into subVI's  when I might need to hack back into it at a later date and change it.
Would you also write a VBA program without functions and/or includes? LabVIEW has a nifty little tool where you can just select some code and choose Edit -> Create SubVI. Your big case structures might be a start for that. 🙂
Kudos to you for using Shift registers!
Most of your Select (the triangles) are ANDs.
The LV startup windows has an Example finder (or search in help), the Producer/Consumer is probably what you're after, since i bet not all of this must really be run each iteration, no?
Case structures can be used with integers and doubles also, in which case they work like switch/case or if/then. Many comparisons can be merged into that solution.
Race conditions happens on all multithreaded systems, if you dont control in which order data is read and written to variables it basically becomes random. Local variables give no such control. Just imagine 10 excel applications writing to the same file without file lock, in which order will the data end?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 23 of 53
(1,331 Views)
Here is how I would start. I got a few minutes of cleaning into it.
Tim
GHSP
Message 24 of 53
(1,328 Views)
Aeastet,
Ok, to be perfectly honest, I really can't see what you've done because most of the areas have been rearranged... I have things laid out and organized in sections in the window pertaining to their functions.
All,
I do have a few questions... is there a way to write a VI that has the shift registers built in?  ...say I wanted to VI my counter, do you put a loop in the VI?  This was the first thing that I wanted to subVI because it's huge and quite complicated.  ...but I didn't know how to take care of the shift registers since they're tied to my main while loop.  Any ideas?  I'm thinking I can put a loop in the vi with all of the separate inputs/outputs... is my thinking correct?
One of the guys mentioned that I'm using local varialbles... I'm not seeing where I'm using local varaibles as described in the Help files.  At least not in the way that I'm understanding it.  If you'll point one out so I can better understand I'd appreciate it.
Thanks!
C
Message 25 of 53
(1,319 Views)
Great for you to jump in feet first!  and a heck of a way to start!  We really aren't picking on you too much when we suggest modularizing your code by using sub-vis (think sub-routine).  Just grouping related code so that it  fits on one screen section is a good place to start but not enough.  Make it a sub-vi so it gets its own block diagram and gets away from unrelated code it will be much easier to read and maintain ESPECIALLY when you add VI documantation and commentsSmiley Wink
"Express vi's are those darn huge blue icons that get configured.  Pro's detest them because they perform poorly.  There is a lot of code behind them that follows the 90/10 rules.  90% of the code is not used often (think exception cases) and the 10% you need can usually be accomplished with a couple functions on the palatte.  For instance Write to spreadsheet file.vi on the file palatte would format your file just fine and use less memory.
Did you ever look at the task manager to verify that LabVIEW is the resouce hog?
Message 26 of 53
(1,330 Views)
Thanks!  Smiley Happy  I understand you aren't picking on me... I realize that I need to shrink this down.  I'm just to green at this point to see all the short cuts that all you experienced guys/gals notice.  Basically, I know just enough to be really dangerious at this point!  Smiley Very Happy
I've written one other controls program using LV... a precursor to this if you will, that occasionally had the same issue, but once I turned it into a standalone executable those issues went away.  I've got alot to digest and read so I may take a step back and do some reprogramming.
...and to answer your question, I typically have the task manager running and LV is chewing up a lot of memory.
THX
C
Message 27 of 53
(1,322 Views)
Thanks!
C
Yes, Shift registers is fine to put in your sub-vi's. It's a common way to keep a memory between loops (uninitialized shift register).
/Y
Qestit Systems
Message 28 of 53
(1,300 Views)
THX
C
THat points back to my wild guess of an array growing somewhere. (After some poking I suspect a filter is building a hsitory or the DAQExpress VI is not deallocating buffers and it needs broke up inot "init before" Read inside" "Close afterwards" to avoid the buffers being repeatedly reallocated.
Run the VI profiler and figure whick VI is using increaling memory. Once we know that, we can focus on a fix.
So run the rofiler and proceed based on what it tells us.
Ben
Message 29 of 53
(1,288 Views)
LV in general eats alot of memory, the real question is if it increases. 🙂
Qestit Systems
Message 30 of 53
(1,276 Views)
