VI's in Library can't see block diagram
I'm trying to access the block diagram for some VI's in a LLB file, but this option is not available when you go Window->Show Block Diagram
Also no possible to edit the VI properties.
Any reason for this ?
(2,710 Views)
The block diagram can be removed. Once this is done, the VI can no longer be edited or upgraded to a new LabVIEW version.
If you want to edit the VI, you need to request a VI containing the block diagram from the original developer.
Click here for Details
(2,707 Views)
