VI's memory footprint on disk
Hi community,
I have recently made changes to a VI and it has grown by 5 MB.
I may have accidentally have saved some huge array input a default value or something similar.
The problem is: how do I find where? The vi has a rather big and nested block diagram.
All the tools I'm aware of analyse the memory footprint in RAM at runtime - I don't care for that at the moment, the memory consumption of the vi on disk is all that bothers me.
Any ideas?
Florian
Message 1 of 21
(3,973 Views)
Well, how many controls, indicators and constants can you have? Just check them.
Else you'll have to do a search like this:
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 21
(3,968 Views)
I don't know how many in can have - but this is the UI of a very big application and has a lot. Smiley Sad
Thanks for the snippet.
It seems that the issue is something else though. The biggest items were pictures that were already there before the changes (and they weren't even that big).
Any ideas how the size of the VI could have increased by 5 MB (from 7 MB to 12 MB)?
Most of what I did was of course done in sub VIs. The changes from the perspective of this UI vi should be minimal - a view exchanged sub VIs mostly.
Is there a more general approach to analysing the memory footprint of a vie on disk?
Message 3 of 21
(3,956 Views)
It sounds like a data copy of sorts, have you created a constant from a filled array? Did you manage to copy a front panel picture? Something like that has happened.
/Y
Qestit Systems
Message 4 of 21
(3,936 Views)
May I ask why you are so concerned about 5mb of additional file size?
aputman
Message 5 of 21
(3,911 Views)
Good question.
Mainly because I'm concerned that I have not accidentally saved a huge picture or array into the vi and that there's something else "wrong" with it (though there isn't necessarily anything wrong with it).
I can't display the vi hierarchy of that VI - the window stays blank (may just be too big).
Lately sometimes the development system has crashed when working with that project.
The 5 MB are a 70% increase in size - I just found that suspicious, and was wondering if there was any route for diagnostics.
Message 6 of 21
(3,896 Views)
You can check where the memory is located. Open VI Settings and select Memory Usage.
I assume that the rise in memory is in front panel. If so, you have to check default values. A common source of unwanted default values is to accidently (or by pure misunderstanding) Edit >> Make Current Values Default.
Please note that removing default values is, in most cases, simpliest by recreating the controls/indicators. Otherwise use property nodes to write empty values (e.g. empty array) to the control/indicator. Please note that for scalar elements, this most often does not work, which means that they still keep a default value unless you recreate the element.
If the source is the block diagram, look for huge constants.
Norbert
Expert: Geometry
Message 7 of 21
(3,887 Views)
Thanks for pointing that out.
I'll look into it. Here are the values in case someone is interested:
FP-O: 2675.6K
BD-O: 15425.6K
Code: 3582.9K
Data: 7837.5K
Total: ~29521.7K
On disk: ~12023.1K
Code complexity: 17.4
last compiled: partial comp. optimisation
Message 8 of 21
(3,881 Views)
Ok, I dug up a backup of the vi made before the changes:
FP-O: 2628.1K
BD-O: 14998.1K
Code: 3586.6K
Data: 7837.5K
Total: ~29040.4K
On disk: ~7013.3K
Code complexity: 17.5
The values seem rather similar to the new one (post above) - except for the size on disk part.
The files are in the same uncompressed folder.
Any idea what the difference might be?
Florian
Message 9 of 21
(3,874 Views)
I am not sure about why this is happening. Please make the following test:
Copy the whole BD and paste it into a new VI. Save that. What is memory usage looking like for the new VI?
Norbert
Expert: Geometry
Message 10 of 21
(3,867 Views)
