VI's to demonstrate RZ and NRZ sampling?
i would like to know if there are any Vi's that can be used to demonstrate RZ as well as NRZ sampling.if not can u suggest any techniques that i can employ in orderto do this. I would also like to demonstrate aliasing!
(3,032 Views)
Hello St Augustine,
Thank you for your inquiry regarding sampling examples in LabVIEW. It sounds like you would like to demonstrate different sampling techniques. Is there any specific hardware that are using that you would like to demonstrate these effects of some of these things. I have provided some links that should get you headed in the right direction.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3DBE356A4E034080020E74861&p_node=DZ52008&p_source=External
This link applies to aliasing...
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3D82356A4E034080020E74861&p_node=DZ52000&p_submitted=&p_rank=&p_answer=&p_source=External
Other resources similar to this can be found on the ni.com website by clicki
ng the support tab at the top of the home page. Then scroll down to "Example Code" towards the bottom of the page. There you can search for �Referenced Sampling Demonstrations� or topics similar to this. I hope these resources help. Let me know if I can further assist you.
Shea C.
Applications Engineering
(3,032 Views)
